Configuration failed
tko
Post by tko »
I have done a simple Installation package with the current 6.42 release.
It works with the uncompressed Build without any problem.
But when starting the setup with compressed single self-installing.exe or compressed web-based exe - it fails when i start the setup on every testcomputer.
Even when i configure to not use any compression, the same problem exists.
Even worse - when i configure to log the setup, nothing happens - except the small messagebox.
Any Idea ?
i have enclosed a compressed websetup file. (it's a german freeware application)
csk verträgeverwaltung.exe
Please name your main setup.exe file without using German characters. This is just for the final output setup file - the rest of your setup can freely use those characters.
