Calling a DLL from $SUPPORTDIR$ and Return Value
Superfreak3
Post by Superfreak3 »
Currently, I added a custom .dll to Support Files and want to call it from the Next button of our serialization dialog. Here is the logic since I don't know how to actually call something from the dialog control mentioned or if I just script....
label: Serialize
if variable WIZARD Equals Back
GoTo Label: Readme Information
else
if variable WIZARD Equals CANCEL
GoTo label: Main Install
Set Variable APP_VALID to 0
Call DLL Function $SUPPORTDIR$\\Our.dll->_OurFunction (get result into variable APP_VALID)
Now since I'm conditioning another dialog to appear if serial numbers are entered incorrectly or are invalid, which Return Type should I use on the Call DLL Function to receive a 1 or a 0.
Then, after receiving the 1 or 0, I need to call a dialog indicating the serial number entry was invalid (if 0 returned). Would I just append or insert this after the code snippet above...
if APP_VALID Equals 0
GoTo label: Bad Entry
Then Bad Entry might be....
label: Bad Entry
if variable WIZARD Equals Retry (there will be a retry button to return to the serial entry dialog)
GoTo Label: Serialize
Any HELP :? is GREATLY Appreciated
