Apparently the value ImagePath under HKLM\\SYSTEM\\CurrentControlSet\\Services\\<My> gets an added space at the end.
This poses a problem, since our product does not expect the space to be there.
Is this a known bug?
(Btw: tried to overwrite the key with the correct value, but this fails)
after install service: regkey ImagePath has extra space?
Chris Miller
I'm seeing this bug with IA 7.5. This is a problem becuase I have a service written in .NET and the configuration program that updates the .config file for that app uses ImagePath and concatenates ".config" to it to get the location of the .config file. This breaks with IA because of the extra space.
Chris Miller
[url=http://www.versatrans.com]Tyler Technologies[/url]
[url=http://anotherlab.rajapet.net]My blog[/url]
[url=http://www.linkedin.com/in/christophermiller]My LinkedIn profile[/url]
Chris Miller
I don't know if this helps anyone, but I implemented a work around in my service. Or more accurately, the configuration utility that edits the service settings. It uses the ImagePath value to get the path to the service file name so that it can access the .config file (it's written in .NET, most of the settings are in the app.config instead of the registry). I made the configuration utility more tolerant of the values in ImagePath.
An alternative would be to make the service self-registering. I did that when I used Wise For Windows, as their service registration code would fail spectaculiarly with services written in .NET. It's fairly easy to make your service self-registering. The API apparently isn't documented, but the Framewark calls to register as a service are easy enough to use. If anyone needs to do that, I wrote it up here.
Chris Miller
