MS SQL Authentication
jimo
Postby jimo » Mon Aug 22, 2005 3:56 pm
Is there any way to use a trusted connection instead of using a SQL named user?
sinan
Postby sinan » Mon Aug 22, 2005 5:10 pm
If you leave the username field empty, you will get Windows authentication. Is this what you need?
jimo
Postby jimo » Mon Aug 22, 2005 6:32 pm
yes, thank you, although I can not get my sql script to work, I have run it in SQL Query Analyzer and it works fine.
Users browsing this forum: No registered users and 16 guests
