Command line builds and version number
mbenedict
Post by mbenedict »
I would like to use the InstallAware command line options from within Visual Studio to generate a setup after I make an update to my application. How can I update the project version from the command line so that it matches the version of the application I'm shipping out?
Alternatively, is there a way to specify that the version should always be the same as the version number of a specific file?
neillans
Post by neillans »
At present this is not supported, but you can search / replace on the mpr file for the old version - the mpr file is a plain text file, so this will not cause any problems.
Andy Neillans
