Install/Remove MSI Package Command
zchris
Postby zchris » Tue Aug 23, 2005 2:18 am
I am trying to use the Install/Remove MSI Package command with an IA generated setup:
Install/Remove MSI Package $SUPPORTDIR$\\CamComponents-Setup.exe[ADDLOCAL=ALL] (get result into variable SUCCESS2)
(the "Package is IA generated installation" option is checked)
However when I run the setup I get this error:
"This installation package could not be opened. Contact the application vendor to verify that this is a valid Windows Installer package"
How can I fix this?
sinan
Postby sinan » Tue Aug 23, 2005 7:01 am
Ah, if you are trying to install an InstallAware setup, the recommended method is by running the InstallAware exe file. You may run it silently using the /s command line option, and also specify other options.
zchris
Postby zchris » Tue Aug 23, 2005 10:34 am
OK.
Could you possibly add this for a future version? It would be nice if I could display the progress on the same form (otherwise the setup appears to hang).
Thanks!
sinan
Postby sinan » Tue Aug 23, 2005 3:31 pm
Sure.
Users browsing this forum: No registered users and 42 guests
