Hide setup from \"Add or Remove Programs\" dialog
zchris
Postby zchris » Tue Aug 23, 2005 10:40 am
How can I hide my setup from the "Add or Remove Programs" dialog?
Also how can I hide the modify button in "Add or Remove Programs"?
Thanks!
sinan
Postby sinan » Tue Aug 23, 2005 3:33 pm
Its all in the registry.
Depending on All Users or Just Me install, look under HKLM or HKCU.
SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\$TITLE$.
You can delete this key - after Apply Install.
zchris
Postby zchris » Wed Aug 24, 2005 3:53 am
The key is under HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Uninstall\\$TITLE$ - but otherwise it works perfectly.
Do you know why the setup is also listed under HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Uninstall\\$product_code$?
As always - thanks for the quick reply!
sinan
Postby sinan » Wed Aug 24, 2005 6:51 am
Ah yes of course, sorry I forgot about the uninstall part :)
It should not be listed under product code...that key is normally removed by InstallAware (or at least, it should not be visible in Add-Remove).
Users browsing this forum: Baidu [Spider] and 13 guests
