1. I have installed a .net service with the .net installutil.exe by using the "Run Program" dragdrop. Is there a way to start the service afterwards?, I've tried "Control Service" (start on install) but nothing happens. Does the "Control Service" need to be before "Apply Install"?
2. Since I'm using installutil.exe I need the folder where its located, the ".net 2.0 framework" folder. Is there a way to get that folder?. Or do I need to make a plugin wich calls "GetCORSystemDirectory"?
