Running Setup Squeezer from command-line
baustin
Post by baustin »
Is there a way to run Setup Squeezer for MSIs from the command-line? I would like to add it to our build process, but couldn't find any way to automate the GUI.
thanks,
Brent
baustin
Post by baustin »
If it isn't possible to run Setup Squeezer from the command-line, is the functionality of Setup Squeezer available in some other product? Specifically, I want to take an existing .msi file and recompress (using LZMA) it into a self-extracting installer. Is that what the "Import MSI/MSM Windows Installer Database" feature of InstallAware Studio Admin does? If so, is Studio Admin the only version of InstallAware that will do what I want?
thanks,
Brent
Post by CandiceJones »
Hi Brent,
InstallAware contains a superset of Setup Squeezer's functionality; however I don't believe the tools there can be automated in the manner you want - there is an automation interface, but it doesn't cover setup recompression.
