package with online registration
farangtoone
Postby farangtoone » Tue Apr 24, 2007 9:46 pm
Dear forum surfers,
I am quite new to InstallAware, I am currently using the trial version but I wanna get the licensed version. Now I have 2 questions:
1. I want to be able to use an online registration, can i do that with the developer version?
2. how can i do the online registration? Do i need to put a database online with all the serials or how does it work? I have checked the example file "online user authentication" but i am not really an asp programmer so I don't know how to create that file.
Please help me out,
best regards
Toon
Postby CandiceJones » Wed Apr 25, 2007 5:51 am
Hi Toon,
You will need to build your own server logic to handle the online registration. The ASP file referred to in the pre-built sample doesn't exist; its just meant as a placeholder.
farangtoone
Postby farangtoone » Wed Apr 25, 2007 9:20 pm
Thanks for the quick reply.
Do you have any suggestion? php with mysql for example? Would that work?
Postby CandiceJones » Thu Apr 26, 2007 6:55 am
Sorry, that isn't an installation related question; its not something we can help you with (although we would love to).
farangtoone
Postby farangtoone » Thu Apr 26, 2007 10:05 pm
I understand but your sample requires a type of file so I have to wonder what your program needs in return. Your program will connect to this page and then what? download the file and then verify the information? Or verify on this page? You must have created this sample code with the intention to make a real program work.
Thanks in advance
Toon
Postby CandiceJones » Fri Apr 27, 2007 6:32 am
If you look at the sample project, you will see that after calling that file, it reads the contents to see if the user is authorized or not. You may also look at your own custom file contents in a similar way.
farangtoone
Postby farangtoone » Mon Apr 30, 2007 3:26 am
problem solved, if anyone is stuck on this as well just contact me straight. I'll help you out.
cheers~
GordonS
Postby GordonS » Mon Jun 18, 2007 4:30 am
CandiceJones wrote:If you look at the sample project, you will see that after calling that file, it reads the contents to see if the user is authorized or not. You may also look at your own custom file contents in a similar way.
Am I just being dumb? I can't presently see where within InstallAware this is setup/done.
IA Express 6.6
Postby CandiceJones » Mon Jun 18, 2007 2:50 pm
You cannot see it in Express - you need access to the script.
Return to “Non-Technical”
Users browsing this forum: No registered users and 29 guests
