Error during build
AndersO
Error during build
Post by AndersO »
I'm getting an error during build, right at the start after it has cleared the release folder, not sure what it means:
"Error during build: At least one Web Media Block must be defined before installation commands that may require media"
Please add a Web Media Block command to your script above, for example, an Install Files command or a plug-in that installs a runtime; there is one of those commands which doesn't fall inside a web media block at this time.
AndersO
Post by AndersO »
I added a Web Media Block at the very top off my script and it started to build. Not sure what it exactly does though must read up about it.
You definitely should! Its one of the strongest and most interesting features of InstallAware. Just double-click the MSIcode command and then press F1 to begin learning more.
