InstallAware 2005 Second Edition Now Available
sinan
Postby sinan » Thu Aug 25, 2005 8:15 pm
Download it now!
http://www.installaware.com/home/download.asp
If you are a licensed user, your upgrade is free. If you are a trial user, be sure to try out this latest and greatest release.
A very brief what's new list (for the full list, see the help file after installing the product):
IDE:
    Code Folding
    In-Place Editing
    Project Converters
    Sample Projects
Tools:
    Localization Wizard
    Group Policy Wizard
    Automatic Setup Decompressor
Setup Engine:
    256 bit AES Encryption
    Multi Lingual Setups
    Light Mode Setups
    Dynamic Setup Features
    Transparency and Alpha Blending
Enjoy!
Sinan
zchris
Postby zchris » Mon Aug 29, 2005 5:05 am
Thanks for the free upgrade! :D
I discovered one problem however: when I add an icon to my project (options: add/remove) and select "Build: compressed single self installing exe" then the generated exe will not be valid. Windows will display the error "...exe is not a valid Win32 application." when I try to start it.
When I remove the icon from the project everything is fine.
I am using the Studio edition (licensed).
jimo
Postby jimo » Mon Aug 29, 2005 7:37 am
I also noticed this, I have checked my icon and it has the same 6 formats as the icon contained in dependent.exe.
sinan
Postby sinan » Mon Aug 29, 2005 1:08 pm
Could you try different icons and see if that works?
We've been getting lots of reports about this, it might require an update, but I'm not yet sure what the extent of the problem is...
jimo
Postby jimo » Mon Aug 29, 2005 1:22 pm
I have tried an icon that has 6 formats, an icon that has 2 formats and an icon that has one format, same problem no matter which icon I use. I also tried several other icons at random from other people and am getting the same result.
sinan
Postby sinan » Mon Aug 29, 2005 1:30 pm
Can you please send me some of those icons? I'll escalate this and get it sorted out. Thank you.
sinan
Postby sinan » Mon Aug 29, 2005 5:20 pm
This issue has been resolved - thanks for reporting it.
Licensed users may simply log on to their account, regenerate and reinstall their license to obtain the IDE (and related build tools) which no longer exhibit this problem.
And, we will update the trial downloads within 24 hours of this posting, into versions which do not exhibit this problem.
Thanks again for spotting this one,
Sinan
jimo
Postby jimo » Mon Aug 29, 2005 6:23 pm
Works great!
Thanks!
sinan
Postby sinan » Mon Aug 29, 2005 7:02 pm
Sure thing :D
zchris
Postby zchris » Tue Aug 30, 2005 1:25 am
Nice to know that somebody is working while I sleep :)
I downloaded and installed the new license.
Building from the IDE is now fixed however miabuild still has the error.
miabuild.exe setup.mpr /r
Could you take a look at it as well? Thanks!
sinan
Postby sinan » Tue Aug 30, 2005 9:09 am
Ah, miabuild is not updated by the licensing package, that's got to be why. I've put the fixed copy of it online for your convenience. If you install the latest public trial and then apply the licensing, since the trial has also been updated now, you won't experience this problem.
http://67.19.88.228/torrent/miabuild.exe
zchris
Postby zchris » Tue Aug 30, 2005 11:18 am
The new miabuild works great, thanks! :D
sinan
Postby sinan » Tue Aug 30, 2005 11:50 am
Sure thing - thanks again for spotting this one out :lol:
Users browsing this forum: No registered users and 59 guests
