error in webinstall of .net sdk 1.1 sp1
msaint
Postby msaint » Sat Apr 28, 2007 1:20 pm
I am at my wit's end trying to figure out how to correct this problem. My installers fail to install .net sdk 1.1 sp1 with the following error:
Error 1308: Source file not found: C:\\Documents and Settings\\All users\\Application Data\\{54AFDF9D-B866-4CB1-8F355-04BC3ABAB1CE}\\Microsoft .NET Framework 1.1 with Service Pack 1\\mDotNet.dll\\Win\\Microsoft .Net\\Framework\\URTInstallPath\\System.Runtime.Serialization.Formatters.Soap.dll. Verify that the file exists and that you can access it.
Thanks for any help.
-msaint
Postby MichaelNesmith » Sat Apr 28, 2007 7:55 pm
Are you getting this with the latest 6.5 build?
msaint
Postby msaint » Sun Apr 29, 2007 1:59 am
I started getting this in 6.4, I tried updating to 6.5 but I still get the error.
Postby MichaelNesmith » Sun Apr 29, 2007 7:07 am
I'm not able to reproduce this with the latest 6.5 version.
msaint
Postby msaint » Sun Apr 29, 2007 11:09 am
One possible reason/condition for this error is the following: since first discovering the error I have only been able to test it on machines where .NET 1.1 sp1 has been uninstalled, not where it was never installed.
BTW, I have tried building a whole new install in 6.5, and I still get the error.
The install exe and the web files are all at www.smash-software.com/podlift0.4.6.4/ (you can list this directory) if you can and are willing to test the install directly to see if you get the error on a .NET free system.
Thanks much for your help.
-Marc Saint
msaint
Postby msaint » Wed May 02, 2007 2:10 am
Is this problem really unique to me?
Web install of .net 1.1 sp1 fails, at least on systems where .net has been uninstalled.
I have tried updating to 6.5, I have tried building a whole new install from scratch, I have tried building the .net web file on a different machine . . .
What else can I try? Or is this a special case when .net has been uninstalled that it doens't work?
-msaint
msaint
Postby msaint » Wed May 02, 2007 3:20 am
OK, weirdness.
I built the .net web file on a different machine using a different setup and it works. I have substituted that copy of the web file in the the install I am having trouble with and that works too. For now I can live with this work around, but I have no idea what this means in terms of what is wrong.
Is my installation of IA corrupt and remained so when I updated to 6.5? Any suggestions?
-msaint
Users browsing this forum: No registered users and 131 guests
