Hello NG,
I want use the new feature "COPYWEBLOCK"of version 6.5. I want that the setup download and save the webblocks to the setuppath (the path where the user starts the setup). When I set the variable COPYWEBLOCK to $EXEDIR$, i cant find the blocks in this directorie?
Is the code allright?
[DEFINE REGION: Check/Install Application Pre-Requisites]
Set Variable COPYWEBLOCK to $EXEDIR$
Thanks Karsten
How works COPYWEBLOCK?
Be sure that you are looking in the right folder.
Display a message box with $EXEDIR$ to be certain.
Also be sure each web media block is executing. Web media blocks that do not execute will not be downloaded and/or copied.
