Why doesn't installaware's self-heal repair the registry fil
Jesús Vargas
Post by Jesús Vargas »
I’m making a test with your product, I unregistered a DLL file that is necessary to may application works, when I use the repair option it works but the file stills unregistered.
All files (.dll and .ocx) that my application depends on are in the application folder
Some suggestion?
Thanks in advance
SteveX
Registering DLL's
Post by SteveX »
I have been using Import in the Setup Architecture|Registry section with great results. Just don't forget to edit the hardcoded paths.
It is my understanding this is the proper way to do it, especially on Vista.
Jesús Vargas
It Works
Thanks Steve,
It works find, but when I uninstall the application the DLL and OCX files repaired stills in the application folder.
I’m deploying with my application about 60 (DLL and OCX Files), each one of that has an Install File command in the Script and the option "File is Self Registering DLL" is selected.
I can’t understand what's the problem.
