Wise Import Wizard Problem
SteveX
Post by SteveX »
Seems that the Wise Import Wizard is setting all files as self registering DLL's and shared fiiles. This includes EXE's, miscellaneious data files, XML files and even txt files. Kind of a bummer.
Same results with two different Wise Install imports (wse), version 6.6 Installaware Studio Admin.
Each imported install did have self registering DLL's as the first file installed, didn't check to see if it happens if a different file type is installed first.
