I user Installaware 6.42. When I build a new installer this is not able to uninstall the old version when the data-directory from the old installer-location on the network is already deleted.
It says "Error Zugriff auf die Netzwerkadresse \\\\server\\installerlocation\\data war nicht möglich."
Which means "Access to networkpath "..." not possible."
How ca I prevent from the need of the old install-location?
Thanx Marc
Installer needs ancient data-directory
By using a compressed or web build.
I don't believe there is a problem with that plug-in copying its files correctly during a build. There used to be some plug-in bugs in third party plug-ins but the latest versions of InstallAware added built-in workarounds for those. So you should just be able to rebuild your setup.
Users browsing this forum: No registered users and 112 guests
