Terminate Process (revisited)
jgrubb
Post by jgrubb »
I need to shut down a process without a window. Therefore no window title, and the class name is auto-generated (.NET window)
I have looked through the forums a bit, and found this information.
Gizm0 wrote:Well you are not lucky,i'm out of town and i don't have my InstallAWARE here, so i can create a script for you.. It's quite easy actually, you have to call an API to do it.. It's TerminateProcess and before that you have to get the process handle by it's process name. To do that you have to EnumProcesses ( read here -> http://msdn.microsoft.com/library/defau ... cesses.asp ) and get the PIDs and then using the pids to get the process name/handle.
If what I am understanding from this post, it says to make an API call to psapi.dll to enumerate through the running processes.
I have written a c++ program to do this. Thats no problem. How do I link something like this to my InstallAware setup script? The only options I have come up with have been to build a dll that performs the following code, include it in the setup script, and then make a call to the dll. before running the main install. Does this make sense?
DWORD aProcesses [1024], cbNeeded, cProcesses;
if(!EnumProcesses(aProcesses, sizeof(aProcesses), &cbNeeded))
return 0;
cProcesses = cbNeeded / sizeof(DWORD);
for(int i = 0; i < cProcesses; i++)
HANDLE hProcess = OpenProcess(PROCESS_QUERY_INFORMATION | PROCESS_VM_READ, FALSE, aProcesses);
if(hProcess == NULL)
continue;
HMODULE hMod;
if(!EnumProcessModules(hProcess, &hMod, sizeof(hMod), &cbNeeded))
continue;
TCHAR szProcName[1024];
GetModuleBaseName(hProcess, hMod, szProcName, 1024/sizeof(TCHAR));
// if the correct process name, terminate it.
I am not getting anywhere with this. I could really use a hand.
You can certainly build a DLL with that code and call it from InstallAware using the Call DLL Function plug-in; or you could author a full blown plug-in for use with InstallAware directly.
jgrubb
Post by jgrubb »
MichaelNesmith wrote:You can certainly build a DLL with that code and call it from InstallAware using the Call DLL Function plug-in; or you could author a full blown plug-in for use with InstallAware directly.
Could you maybe point me in the right direction for information about writing plug-ins for InstallAware?
EDIT: Nevermind, I was able to find how to do it in the InstallAware help section of the program.
The help file contains detailed documentation on the required plug-in exports. The IDE offers two templates for the Visual C++ and Delphi languages.
Marco
Post by Marco »
Can this be done with the MSI Code or only by a plug-in?
Peace in Christ
Marco Napoli
http://www.ourlovingmother.org
swarovski
Post by swarovski »
Try AutoIt.
$PEXISTS = ProcessExists("iexplore.exe")
If $PEXISTS <> 0 Then
ProcessClose($PEXISTS)
EndIf
I have used it and put the executable in the Setup.exe
Use plug-in Filebag and run it during the installation process.
Marco
Post by Marco »
Hi swarovski,
Thanks for the suggestion. We just recently purchased Installaware and I tried to add the Plugin Filebag but I cannot figure out what to do.
Do you have any steps for me to follow for your suggestion?
Thank you.
Peace in Christ
Marco Napoli
swarovski
Post by swarovski »
In the File Bag dialog, u see 3 textboxes right?
You only need the 1st and the 3rd textbox.
File to include: input or browse the full path of the executable.
e.g. C:\\Deployment\\bin\\terminate.exe
In the 3rd textbox, i.e. Variable to receive runtime location of files.
type an variable name.
e.g. fileBagTerminate
The file bag plugin part is done!
Now, in your setup code,
You can use MessageBox
and type this in the message:
fileBagTerminate = $fileBagTerminate$
$ sign here is like de-reference a variable.
i.e. showing the content of the variable.
So that you can debug if the file bag is correct.
Then add a Run Program: (type run program in the script editor):
in the Run Program field type:
$fileBagTerminate$Terminate.exe
that's it!
Marco wrote:Hi swarovski,
Thank you.
Marco
Post by Marco »
Thanks a lot for the details steps. I have added them to my setup script but I am having a few issues.
1. The terminate.exe program, that would be my program that is running correct? Or is it a program that has code to shut down a running program?
2. For the fileBagTerminate I selected my exe program that I want to install, is this correct? When I trace it, this variable shows the path to the fileBag plugin folder, weird...
Here is my code below:
Set Variable fileBagTerminate to
Define File Bag : D:\\Distribution\\MyRolodex.exe, get runtime location of files into variable fileBagTerminate
MessageBox: $TITLE$ Setup, fileBagTerminate = $fileBagTerminate$
Run Program $fileBagTerminate$MyRolodex.exe
3. Where does the below code belong? I cannot add it to the Installaware script:
EndIf
Thanks a lot, I really appreciate this help.
Peace in Christ
Marco Napoli
swarovski
Post by swarovski »
ahhaha
1. the terminate.exe is just an example.
you are right, it's a program that is compiled by AutoIt to shutdown a running program.
2. that's correct. that's the temporarily folder.
3. Those scripts is AutoIt script. Try search AutoIt on google.
Then compile the script into terminate.exe.
Marco wrote:Thanks a lot for the details steps. I have added them to my setup script but I am having a few issues.
EndIf
Marco
Post by Marco »
I am almost there. I got it working when I run the original setup.exe to install and to remove the application, it now Terminates the Process correctly with the AutoIt.
But what is very interesting, if I click on the shortcut created that says Uninstall MyRolodex then I receive an pop up windows that asks for the original setup files... weird. I am not sure what I did wrong. My code is below.
I placed my code in the Uninstallation Region. But when I add the code to Terminate the Process using FileBag it gives error when compiling that says that I need to add at least one Web Region, which I did. I wonder if this is what is causing the lookup pop at runtime?
[DEFINE REGION: Perform Uninstallation]
if Variable REMOVE Equals TRUE
Comment: Uninstall product
Comment: TO-DO: Insert any additional uninstall commands here
[OFFLINE CONTENT]
Set Variable TerminateMyRolodex to
Define File Bag : D:\\Distribute\\TerminateMyRolodex.exe, get runtime location of files into variable TerminateMyRolodex
Run Program $TerminateMyRolodex$TerminateMyRolodex.exe
Apply Uninstall (get result into variable SUCCESS)
Set Variable PROGRESS to 100
else
Thank you so much.
Peace in Christ
Marco Napoli
swarovski
Post by swarovski »
Don't worry hehe.
I hit the same problem when I was started to use IA.
Change the build from Single File to Web Deploy will not ask you that location again~~~
Try try XD
Marco wrote:I am almost there. I got it working when I run the original setup.exe to install and to remove the application, it now Terminates the Process correctly with the AutoIt.
[OFFLINE CONTENT]
else
Thank you so much.
Marco
Post by Marco »
Thanks for the suggestion, go figure... Part of the learning process.
Peace in Christ
Marco Napoli
