Code Sign Vendor
swarovski
Code Sign Vendor
Postby swarovski » Wed May 09, 2007 8:16 am
Hi All,
I am seeking a code sign vendor for the installer that built from InstallAware.
After searching IA forum, i found 3:
VeriSign
thawte
COMODO
I want to know which one you will suggest?
The choosing factor would be:
- fully compatible with IA (i am using IA 6.6 now)
- price (first time + renewal)
- popularity
- easy to apply
- support
swarovski
Postby swarovski » Wed May 09, 2007 8:20 am
The "fully compatible" i mean is that the key files, cert. etc provided by the code sign vendor can be directly read by IA.
Like the attached screen.
As I want to use the IA Code Sign tool to sign my setup package.
swarovski
Postby swarovski » Wed May 09, 2007 12:32 pm
Just find another vendor:
GlobalSign
Still looking for recommendations.
Anyone have some nice idea to share??
Postby MichaelNesmith » Wed May 09, 2007 1:28 pm
At InstallAware we use Comodo. Their certificates do not cost a fortune ;) But certificates from any vendor should work just fine, as long as you generate digital code signing certificates in spc and pvk pairs.
swarovski
Postby swarovski » Wed May 09, 2007 8:35 pm
Thank you!
swarovski
Postby swarovski » Tue May 15, 2007 11:38 am
Any other users have suggestions?
I am looking more details on Comodo too. It seems that it is cheaper relatively and the web site is easy to do the registration.
swarovski
Postby swarovski » Sun Jun 03, 2007 10:23 pm
Find one more:
https://www.thawte.com/ssl-digital-cert ... index.html
Price is cheaper relatively. And also there's lots of guides in PDF really good and clear for beginners.
Users browsing this forum: No registered users and 72 guests
