How many code sign certificates do I need?
swarovski
Post by swarovski »
I have to build a installer using IA.
There are 1 program executable (.exe) and 1 browser helper object for IE (.dll) inside the installer.
Do i need 3 separate certificates?
1 for installer
1 for exe
1 for dll
Or just simply 1 cert. is enough?
Tinus
Post by Tinus »
You need 1 certificate and use it to sign all your code (exe, dll, installer).
Martin Rothschink
AxoNet Software GmbH
swarovski
Post by swarovski »
Tinus wrote:You need 1 certificate and use it to sign all your code (exe, dll, installer).
Coolies.
So 1 certificate is enough for one company rite?
Yes, there is no reason to get more.
swarovski
Post by swarovski »
MichaelNesmith wrote:Yes, there is no reason to get more.
Thank you Mich!
crustyzz
Post by crustyzz »
What kind of certificate do I need ?
There are several kinds of certificate, server, ssl, ...
I don't have any idea of the cost of a certificate, how much it costs per year ?
Could you forward me to the web page of your certificate provider ?
Thanks for your help
