DanielW
Posts: 25 Joined: Fri Feb 23, 2007 7:40 am
Post
by DanielW » Wed May 09, 2007 11:36 am
I made the mistake of manually deleting the application folders on my PC and now I am not able to reinstall the revised application. I get error .."out of sync with client package..". I can't find the application in the remove programs list, either. How can I get past the error to load the new application software.
Dan
Posts: 3452 Joined: Thu Dec 22, 2005 7:17 pm
Post
by MichaelNesmith » Wed May 09, 2007 1:29 pm
You probably want to use msizap on your package's GUID to clean all traces of it from the registry.
DanielW
Post
by DanielW » Wed May 09, 2007 4:08 pm
I was not familiar with this utility, but was able to find it on internet.Thanks! It seems to be installing my application again.
Dan
swarovski
Posts: 109 Joined: Mon Apr 16, 2007 8:32 pm
Post
by swarovski » Mon Jun 18, 2007 8:06 am
MichaelNesmith wrote: You probably want to use msizap on your package's GUID to clean all traces of it from the registry.
thank so much. I found this tool is really useful for me!
FYI, it can be located at:
C:\\Program Files\\Microsoft SDKs\\Windows\\v6.0\\Bin
