The release date on the download page was changed today for the 3rd time in the past week, but the version number was not changed.
What does it mean?
Were there really 3 releases of 6.6 or the release date does not mean anything?
Oren.
What's with those version 6.6 releases??
It means that there were subversion minor fixes (6.6.x.x). If you're not affected by any kind of strange behavior/bug, you don't need to download it.
Panagiotis Kefalidis
Software Design Team Lead
That is correct.
The fixes in the latest 6.6 subversion revision released on the 11th are as follows:
1) Compression occasionally stored incorrect folder paths, leading to runtime setup errors. This only occurred when UNC paths were being used in conjunction with repeated folder names on the same path; or by having a folder named "data" as a parent folder of your project folder.
2) Built-in setup engine dialogs used the wrong character set. They now use the correct character set for the locale of Windows that setup is running on.
In addition, the fixes in the first 6.6 subversion revision released earlier are as follows:
1) Delete Recursive Files command caused an access violation when any files were found.
2) Changing the value of the ALLUSERS variable while running a web build with already-downloaded web media blocks caused an access violation.
If you are running the latest version, the IDE will report:
in the About box.
Always remember to regenerate your license file after installing a newer product version. Installing an older license on top of a newer product version will cause unpredictable behavior.
Version 6.6 (build berlin_rtm.051107)
in the About box.
Users browsing this forum: Baidu [Spider] and 116 guests
