many build types from command line
maurosturaro
Post by maurosturaro »
I need to build many version of my setup from a batch.
The help tell that miabuild accept a parameter /b=<buildtype> where <buildtype> is 0 or 1 or 2 ...
how can I build all that versions with the same revision number ?
I've try
miabuild myproject.mpr /r /b=0 /b=1 /b=2 {...}
but it build only the uncompressed version.
If I run three different command with can I have the same revison number ?
Is the new revision number saved back to the project file ?
The revision number is not saved back to the project file.
What you can do is use a compiler variable for the revision number, and then pass that in during your build.
That way you can do three builds sequentially without using the "/r" parameter.
maurosturaro
thanks, it works.
But for some future release I suggest an option like /b=12 /r to build single-file AND web based with the same new revision code, like is now possible from user interface.
