SQL Server 2005 Express Edition with Advanced Services SP2
candrade
Post by candrade »
Does InstallAware include SQL Server 2005 Express Edition with Advanced Services SP2 as an available runtime? I know it includes the base edition, but I need to also install the reporting services component.
If not, what is the best way to get Advanced Services SQL Express installed ?
You can just build your own runtime for it, use the Run Program command to run the setup.exe file of advanced services, or use the (Un)Install MSI Setup command to directly install the setup.msi file for advanced services.
