Error creating a virtual folder on windows Vista.
ablengio
Post by ablengio »
Hi Forum, I´m trying to create a vistual folder using the command "create virtual folder" (with the basics options) but when I install the product on Wondows Vista nothing seem to happen... An error doesn´t occurs but the virtual directory is not present in the iis.
Is it a known issue? What can I do?
Post by CandiceJones »
You need to install the IIS6 metabase interface on Vista.
