ICE03 Error in MSI Validation
fosnl
Postby fosnl » Wed May 16, 2007 1:14 am
In my project I try to start a service:
Control Service MSSQL$E4O: start on install [wait for completion]
If a run the Database Validation I'm receiving this error:
ICE03 Value exceeds MaxValue; Table: ServiceControl, Column: Wait, Key(s): ID_5bP1B61BB9B_15d
If deselect the 'wait for service state change completion' the command changes to: Control Service MSSQL$E4O: start on install
and the error disappeared when I run the database validation
Is this a bug? - I need to be sure that the service is running before I continue
Postby MichaelNesmith » Thu May 17, 2007 7:20 am
Is this a warning or error?
fosnl
Postby fosnl » Fri May 18, 2007 3:42 am
It's an error. Also when I build and testrun it, it gives an error and the rolls back the installation...
I've buin thinking. Can it be that the 'wait for the servive to start' option is not allowed when the service is not installed by the setup itself? - The service has it own setup and my client has to make sure that its runs.
Postby MichaelNesmith » Tue May 22, 2007 6:43 pm
Actually, it seems like the engine is emitting incorrect MSI database information with that option checked. I have escalated to R&D for a fix.
Postby MichaelNesmith » Fri May 25, 2007 12:35 pm
This issue has been resolved - simply install the latest trial version (and if you are licensed, regenerate and reinstall your license).
Users browsing this forum: No registered users and 116 guests
