I've stumbled upon a funny problem.
Some of my Register Library Commands fail. But the same file works with regsvr32?
Any help / ideas?
D.
Register Library sometimes fails
Re: Register Library sometimes fails
Me 2. I have to use regsvr32 for some of my components. too,dmostert2 wrote:Hi,
Any help / ideas?
D.
Do you think maybe your libraries need their current folder set correctly? You may want to change the current directory to the library folder before calling Register Library.
Not really...you do have two other options available - check the self registering option, or simply capture the registration data into your own setup in the registry view (use the import option).
Registration Fails
@dmostert2
I've had very bad luck using the self registration option. This also happens with other installers I have tried so I believe it has something to do with the specific OCX/DLL and it's use with the Windows Installer - not Installaware. I have since given up on using it all together and am using the Import Option with solid results.
...that was one of the reasons I migrated from Wise to Installaware, because with Wise there is no easy work around to this problem.
Just wish I could nail down the exact cause, but the problem is more predominent on Vista and seems to be related to COM objects that contain no UI elements, at least in my case that has been the common factors.
