Wrong Version of ASP.NET in Default Web Site
DavidCassere
Post by DavidCassere »
2003 Server IIS 6.
I have created a new virtual directory in the default Web Site in a new apllication pool and stated required version as asp.net 2.0. The application pool states correctly that that it is ASP.NET 2 but the entry in the default directory says 1.1. Until I change the entry in the default Web site it doesn't run?.
~InstallAware Clipboard Data~
~Create Virtual Folder~
~{F5D20B80-5845-4754-BDB3-D1D038FFD0A3}~
~Agility29~
~$TARGETDIR$\\LiveSystem~
~TRUE~
~TRUE~
~FALSE~
~FALSE~
~TRUE~
~TRUE~
~2|$APPPOOL$~
~2|2~
~TRUE~
~mainmenu.aspx,Default.htm,Default.asp,index.htm,Default.aspx~
~TRUE~
~TRUE~
~FALSE~
~1~
Maybe you need to use a Create Virtual Folder command for the root directory of the website also? Just leave the "Virtual Path" field empty, as the dialog hint indicates.
