I should of mentioned this before, because it happened on prior builds as well, but I downloaded the May 15th 6.6 build and on installation I get a mmergemod.dll failed to register message. The only way to get past it is by clicking ignore. The dll will not regiser with regsrv either so I am guessing it is not a COM dll as the software seems to run fine without it being registered.
EDIT: ...had the DLL name wrong. It is mergemod.dll, which fails to register. The DLL can be manually registered.
mergemod.dll fails to register
Cannot reproduce (believe it or not, that can be the hardest part sometimes in fixing an issue).
Any steps to consistently create the problem?
Are any other users experiencing the same issue?
More Info
Candice,
I redownloaded the file (Full Install) from a different machine. Reinstalled on 3 different machines. The problem occured on two of the 3. Problem machine Dell Xeon Vista 64, Dell M2010 running XP Pro. The one that didn't have a problem Dell E 520. It's a beta machine that is constantly reconfigured.
I am guessing the problem is related to some of the other registration issues that myself and others have run across. Doesn't happen on all machines, but it is always the same file(s). The fix has been Import .Reg/COM Registration. So the best way to reproduce, is try it on a couple of other machines / OS's.
Steve
Steve
