Update Error
Gradecki
Update Error
Postby Gradecki » Wed May 23, 2007 5:39 pm
Hello:
I created an application with a version of 1.0, then changed a file to a new version and created another setup with a version of 1.0.1 - created a patch against 1.0.
WHen the update was detected by my test system, xp, athlon, I received this error in a command prompt:
16 bit MS-DOS Subsystem
C:\\DOCUME~1\\gradecki\\LOCALS~1\\Temp\\mia4\\MAYUPD~1.EXE
The NTVDM CPU has encountered an illegal instruction.
CS:0def IP:01e5 OP:63 74 69 76 65 Choose 'Close' to terminate the application.
Close Ignore
Gradecki
anotehr test
Postby Gradecki » Fri May 25, 2007 9:55 am
ok, tried another computer and had same error....
has anyone been able to create an application and do updates to it?
Postby MichaelNesmith » Fri May 25, 2007 12:32 pm
It seems the setup engine file is corrupt. This can occur if the InstallAware binaries got corrupted on your system, which in turn can occur due to various reasons:
- cracks,
- corrupt hard disks,
- corrupt memory
Among others.
Gradecki
update error
Postby Gradecki » Sat May 26, 2007 7:49 am
For the corrupt setup engine file. Which file specifically? Is this is update file downloaded from the url specificed for updates or a file(s) put in place by the original install.
Since I've done this now on three different computers will the same result - the original install works fine and the application works - it's just the update downloaded from our web server, I'm sure it's not memory or hard drive issues.
This would lead to the downloaded setup file but I'll need clarification here.
I'm willing to purchase the installer now based on what I've seen but must have updates working correctly - if purchasing will facilitate more targeted technical support - I'm game for that.
Joe
Active Realty Software, LLC
Gradecki
6.6 error
Postby Gradecki » Tue May 29, 2007 8:48 pm
Ok, upgraded to 6.6 and now I don't get the error that I did receive. However, when I click to install the downloaded update, I get a flash of a command prompt and no install.
Version number, size, date, etc are different on the .exe that's being patched - told the system to patch both 1.0.0 and 1.0.1 versions - can I just use x.x.x or does it have to be x.x.x.x?
Users browsing this forum: No registered users and 95 guests
