Logged install
zchris
Logged install
Postby zchris » Mon Sep 05, 2005 8:54 am
I want InstallAware to create a log file of the installation. The commandline switch from the manual does not appear to work.
setup.exe /l=c:\\setup.log
(compressed single self installing setup)
What could be the problem?
sinan
Postby sinan » Mon Sep 05, 2005 9:43 am
The log is only created for the actual setup process. Are you completing an install or uninstall?
zchris
Postby zchris » Mon Sep 05, 2005 10:07 am
Yes, I am doing a full installation.
sinan
Postby sinan » Mon Sep 05, 2005 8:16 pm
Not sure what the problem might be offhand. Check you have access permissions and you are not overwriting the predefined LOGGED variable.
zchris
Postby zchris » Tue Sep 06, 2005 3:19 am
I've tried it again.
It actually creates a logfile while the installation is running but as soon as the "Completing..." dialog is shown the logfile disappears.
sinan
Postby sinan » Tue Sep 06, 2005 6:20 am
I'm really not sure. Any details you can provide?
zchris
Postby zchris » Tue Sep 06, 2005 7:17 am
None that I can think of. Something deletes the logfile after Apply Install.
You can see it yourself however if you run "setup.exe /l=c:\\setup.log" with the file I've emailed you for the "Silent install commandline parameters" problem.
sinan
Postby sinan » Tue Sep 06, 2005 9:14 am
I ran this and the setup.log file was created. I tested on a plain install of Server 2003. Any more details you may provide to help replicate the issue?
zchris
Postby zchris » Tue Sep 06, 2005 12:01 pm
You are right. When I run it on Windows 2003 Server I get a log file at the end of the install.
However when I run it on a Windows XP Pro SP2 (with all updates from Windowsupdate installed) the logfile disappears when the setup is finished.
The XP machine has Windows Installer 3.1 (KB893803) installed - maybe that's the problem?
I hope you can replicate it now.
sinan
Postby sinan » Tue Sep 06, 2005 4:58 pm
Thanks - I will look into it with the additional information.
sinan
Postby sinan » Tue Sep 06, 2005 7:32 pm
We've reproduced and resolved the issue. Expect an update shortly.
zchris
Postby zchris » Wed Sep 07, 2005 2:37 am
Great!
Btw, as far as I know it is not possible to specify a commandline when debugging a setup. Any chance of adding this to the update too?
sinan
Postby sinan » Wed Sep 07, 2005 4:43 am
Not for this release, sorry.
zchris
Postby zchris » Wed Sep 07, 2005 3:19 pm
OK. The logfiles now work fine with your update! Thanks!
zchris
Postby zchris » Tue Sep 13, 2005 7:53 am
Another question:
I need to create logfiles even if the setup terminates before "Apply Install" - is it possible to write my own entries into the logfile?
I tried "Write into Text File $LOGGED$ ..." but the entries get overwritten by "Apply Install".
There is also the problem that "Write into Text File" produces ASCII and standard logs are unicode; if I write to the logfile after apply install the file then becomes garbage.
Users browsing this forum: No registered users and 16 guests
