How to edit INI file
venkat
Postby venkat » Fri May 25, 2007 10:07 am
Bydefault iam specifying path settings as
helplocation=C:\\Program Files\\MyProject\\GRAPHIC HELP\\Help\. while setup user may select other than c drive for example if he choose d drive to install in ini file it has to update as
helplocation=D:\\Program Files\\MyProject\\GRAPHIC HELP\\HelpPlz help me how to solve this problem.
Postby MichaelNesmith » Fri May 25, 2007 12:30 pm
Use variables, such as $TARGETDIR$\\subpath...
venkat
I tried by using $TARGETDIR$ & still it is not working.
Postby venkat » Mon May 28, 2007 11:20 pm
Hi Michael Nesmith,
Thanks for ur suggestion. I tried by using $TARGETDIR$\\subpath eventhoug the Path in the INI file has not been changed.
I used to change path by Edit INI File as
Edit INI File $TARGETDIR$\\test.init, [graphic location] graphic location=$TARGETDIR$\\graphic help\\graphic.
What is wrong in this & why it is not working.
Thanks for ur help.
venkat,[/code]
Users browsing this forum: No registered users and 99 guests
