Is there a way to install one file if feature X was chosen, but install another file (of the same name, to the same location) if feature Y was chosen? No matter what, you get that file, but which file it is depends on the features selection?
Also, can it be done in a more complicated manner - if they chose feature X, they get x, if they chose features X and Y, they get xy, if they chose features Y and Z, they get yz? Always the same file name/location, just different source files...
Conditionally install one file or another?
Feature List
If I understand you correctly this can be done easily by adding specific feature selections to the script. This can be done visually and/or in the script editor.
Conditional Statements
There are really many ways to do it. One of the reasons If statements exist. If this is whatever, do this or not.
I have a Photoshop compatible plugin that actually works in many different programs so I check for each one of them and if they exist I install the plug-in to work with that program. Same file, but installed in multiple places.
Another plugin I have is version specific so if one version is installed it installs one file, if it is another then installs a different one.
InstallAware makes conditional statements easy while it is much more complicated in other setup apps. There are some limitations on nested conditionals, but I haven't run into any problems.
Your best bet is just to try it.
...to actually answer your question
If a feature is selected, it is installed, if not it isn't. Select more than one and they are installed.
OK, i think i get it. At first glance in the code, i didn't see what i needed, but now i think i do...
So i can do something like this:
Get Component ComponentX Selection State into Variable XSELECTED
Get Component ComponentY Selection State into Variable YSELECTED
if Variable XSELECTED Equals TRUE
if Variable YSELECTED Equals TRUE
Install Files ...
Install Files ...
else
Install Files ...
Install Files ...
Is that about right?
Install Files ...
Install Files ...
else
Install Files ...
Install Files ...
