Copy file from installation source
noebby
Post by noebby »
We must copy one licence file to the destination directory which is not included in the install package because it is individual. How to? "Copy Local Files" does not work.
Regards,
Norbert
SteveDude
Copy Files
Post by SteveDude »
I would also like to know a good way to do this. Don't have the time or experience at this point to creat a plugin to handle it. I need a way to copy multiple files from a CD to the local machine. I know this is a Windows Installer limitation, but would be a great addition to IA.
jimo
Post by jimo »
Use call dll.
Here is an example;
~InstallAware Clipboard Data~
~Call DLL Function~
~{89412589-2864-4C5B-B221-63150F855CE7}~
~kernel32.dll,CopyFile,bool,LASTERROR,"pointer to string",$TARGETDIR$\\MDDMBackup,"pointer to string",$TARGETDIR$\\MDDM,$~
~mIDEFunc.dll\\mEXEFunc.dll~
In Engrish;
Call DLL Function kernel32.dll->CopyFile (get result into variable LASTERROR)
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
Bo Andersen
Cant get it to work on win203
Post by Bo Andersen »
Can get the DLL call to work on windows 2003 - Error messages come up saying I need to install the plugin - I call the dll after the apply install.
What I need to do is to create a copy of a file that is installed.. I know I can include the file twice and just install both, but that would bloat my setup-file - are there any other ways?
Bo
ADDED:
Exact error message is
Unable to load plug-in library. Please rebuild your project and make sure all required plug-ins are installed.
Action skipped
ADDED.
Heres the offending command
~Call DLL Function~
~{E4E9FE45-CDED-447C-BA1C-8DC27369C406}~
~$WINSYSDIR$\\kernel32.dll,CopyFile,bool,LASTERROR,"pointer to string",$TARGETDIR$\\DAT\\dnmc.dai,"pointer to string",$TARGETDIR$\\DAT\\emptydnmc.dai,$~
~~mIDEFunc.dll\\mEXEFunc.dll~ ~
and in english
Call DLL Function $WINSYSDIR$\\kernel32.dll->CopyFile (get result into variable LASTERROR)
also tried without the winsysdir...
