Silent install commandline parameters
zchris
Post by zchris »
I am trying to specify a parameter for a silent install.
The script contains a default value for the parameter SERVERNAME:
Set Variable SERVERNAME to localhost
On the commandline I specify setup.exe /s SERVERNAME=test
However in my script $SERVERNAME$ is always empty.
When I do a logged install the log file lists the variables as:
*** Variables ***
UNINSTALLLINK,
CMDLINE,"s /l=c:\\test.log SERVERNAME=test /m=""C:\\SETUP.EXE"" /k=""""",
SERVERNAME,,
Why is SERVERNAME empty?
sinan
Post by sinan »
Shouldn't be. Can you send me your built files and or the setup project so we can look at it?
zchris
Post by zchris »
I've sent you the files via email.
It includes the setup.exe and project files.
Thanks!
sinan
Post by sinan »
I'm not sure why this is happening. I'll have to get back to you on this one after some research.
Can you try other variables, such as pre-defined variables like TARGETDIR, in the interim as a stopgap solution?
sinan
Post by sinan »
I believe we have found the problem. An update will be posted shortly. Thanks for catching this!
zchris
Post by zchris »
Great! Thank you for the quick response! :D
zchris
Post by zchris »
I installed the update and the parameters are now working. Thanks!
