How to create/modify a inifile
jls
Postby jls » Wed Jun 06, 2007 6:01 am
I have attached a simple project where I want to modify a ini file, but it doesn't work.
Any idea what's wrong
Jørgen
jimo
Postby jimo » Sat Jun 09, 2007 12:48 pm
Nothing attached.
This command works for me all the time.
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
jls
Her is my code
Postby jls » Mon Jun 11, 2007 6:48 am
else
Call DLL Function $TARGETDIR$\\testdll.dll->CreateINI
Edit INI File $TARGETDIR$\\test.ini, [Section1] Value=$TARGETDIR$
Run Program $TARGETDIR$\\TestAppMan.exe "$TARGETDIR$" (WAIT)
Run Program $TARGETDIR$\\TestApp.exe "$TARGETDIR$" (WAIT)
The line
doesn't work.
Must test.ini exist in the setupfiles or can it be created by Edit INI File?
jimo
Postby jimo » Mon Jun 11, 2007 7:40 am
Edit INI FIle is a Purple command which means you must place it before Apply Install, you do not need the Call DLL to create the ini file, Edit INI file will create it for you if it does not exist.
Jim Oswell
jls
Everyting works
Postby jls » Mon Jun 11, 2007 8:29 am
Now it works
I added this to test how to create a ini file in a dll (it also works)
Jørgen
Users browsing this forum: No registered users and 73 guests
