Prevent an old setup to overwrite a new version
zchris
Postby zchris » Tue Sep 06, 2005 7:44 am
InstallAware can create setups that automatically uninstall the previous version (take a look at the NEEDSUPGRADE variable in the samples).
Unfortunately it does not detect if the installed version is actually newer than the version you are trying to install.
This can be fixed easily. However it still took me half an hour to implement so I thought I'd share it with you.
Add this to the beginning of your script:
Set Variable VERTODAY to 2005/09/06 10:44
Insert this into your NEEDSUPGRADE branch:
if Variable NEEDSUPGRADE Equals TRUE
  // check installed version
  Read Registry Key HKLM\\SOFTWARE\\Company\\Setups\\$TITLE$ into OLDTODAY
  if Varialbe OLDTODAY Greater Than $VERTODAY$
    MessageBox: Newer Version Detected, A newer version of $TITLE$ is already installed.$NEWLINE$$NEWLINE$Setup will exit.
    Terminate Installation
  // do uninstall
Insert before Apply Install:
// save setup version
Write Registry Key HKLM\\SOFTWARE\\Company\\Setups\\$TITLE$, $VERTODAY$
You only need to set VERTODAY to the current date. If you are building from the commandline you can update it automatically with this C# app:
using System;
using System.IO;
using System.Text;
namespace UpdateVerToday
  class Class1
    [STAThread]
    static void Main(string[] args)
      if (args.Length<1)
        Console.WriteLine("Specify a mia file.");
        return;
      string name=args[0];
      string text;
      Console.WriteLine("Processing file {0}", name);
      using (StreamReader input=new StreamReader(name, Encoding.ASCII))
        text=input.ReadToEnd();
      const int nameLen=8, verLen=16;
      int idx=text.IndexOf("VERTODAY");
      if (idx<0) throw new Exception("Invalid file (no VERTODAY).");
      if (text[idx-1]!='\\n' || text[idx+nameLen]!='\\r')
        throw new Exception("Invalid file (invalid VERTODAY).");
      idx+=nameLen+2; // skip name, lf
      string oldVer=text.Substring(idx, verLen), newVer=DateTime.Now.ToString("yyyy/MM/dd HH:mm");
      Console.WriteLine("Old Version: {0}", oldVer);
      Console.WriteLine("New Version: {0}", newVer);
      string text2=text.Substring(0, idx);
      text2+=newVer;
      text2+=text.Substring(idx+verLen);
      File.Copy(name, name+".verbak", true);
      using (StreamWriter output=new StreamWriter(name, false, Encoding.ASCII))
        output.Write(text2);
      Console.WriteLine("done.");
Return to “Sample Scripts”
