Register Assembly not working for a .NET assembly
Edhy
Post by Edhy »
Hi All,
I have a .NET Assembly which is being used by COM Interop, I am running the code below to register this assembly, but it looks like it is not working.
    else
    Set Environment Variable %MAIN_PROJECT_NAME% to ezCallTrack
    Create Shortcut $SHORTCUTFOLDER$\\ezCallTrack to $TARGETDIR$\\ezCallTrack.exe
    Create Shortcut $DESKTOPDIR$\\ezCall Track to $TARGETDIR$\\ezCallTrack.exe
    Create Folder $TARGETDIR$\\VRep
    Create Folder $TARGETDIR$\\VRep\\Distribution
        Comment: Run Program $BootDrive$\\Progytech\\ezCallTrack\\cdrServer\\R1.bat  (WAIT)
        Comment: Try to register the cdrCryptoLib.dll
        Register assembly $BootDrive$\\Progytech\\ezCallTrack\\cdrServer\\CDRCryptoLib.dll
        Register Library $TARGETDIR$\\ctExplorer.ocx
        Register Library $TARGETDIR$\\ctToolBar.ocx
        Register Library $TARGETDIR$\\VRep\\Distribution\\ctmonth.ocx
        Install Fonts from '$TARGETDIR$\\Fonts\\*.ttf'
        Comment: MessageBox: REGISTRATION, $DEV_REGISTERED_OK$
As you can see the Register assembly code is after the Apply Install, but when I try to use the CDRCryptoLib.dll from my application, I am not able to do so, if I manually from a DOS window run the RegAsm.exe command then I am able to use the library.
I have also tried using the following command:
Run Program $BootDrive$\\Progytech\\ezCallTrack\\cdrServer\\RegAsm.exe $BootDrive$\\Progytech\\ezCallTrack\\cdrServer\\CDRcryptolib.dll" /silent /codebase  (WAIT)
Can anybody tell me what am I doing wrong here?
Thanks!
Edhy Rijo
