Browse For Folder
swarovski
Browse For Folder
Post by swarovski »
In control panel > add-remove.
I select the application (built by IA 6.6).
Select Repair.
Maintenance dialog pop up.
I select Repair.
Click Next button.
Then i got this prompt:
Browse For Folder
Please locate your original setup sources to continue operation.
Even I select where the Setup.exe locates, it keep prompt...
How could I fix this?
jimo
Post by jimo »
You original installation sources need to be stored(cached) uncompressed on th eusers machine or on your distribution media.
Alternatively you can use a WebSetup build type and IA will cache the files locally for you. This way your users will never be prompted for the original sources.
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
swarovski
Post by swarovski »
jimo wrote:You original installation sources need to be stored(cached) uncompressed on th eusers machine or on your distribution media.
Woot. Thank you Jim!
It really works for me~~~
