Error by calling Set Component Space
casic
Post by casic »
I would like to set the correct size for a defined component, but I always get the error "List index out of bounds (16)". Source-Part:
~InstallAWARE Clipboard Data~
~Code Folding Region~
~{653D467B-A590-4A14-AF8E-A742F719D555}~
~FALSE~
~Copy of Copy of ~
~Set Component Space~
~{A994FD97-6136-496C-B91A-33C1EF3A5CAA}~
~DATA~
~10000000~
~{BAF3F106-25DF-46EE-BC63-5A8D1839458E}~
~MSDE~
~400~
~Define Component~
~{C92A8A25-6E7C-4099-837C-EBBB2A4AED8D}~
~MSDE~
~TRUE~
~Description for feature New Feature~
~Define Component~
~{81464AB4-82AD-47AD-AB5E-ACC6FCD84D1F}~
~DATA~
~TRUE~
~{387142E3-0AC6-4600-8A0D-E6CF647E024E}~
~TRUE~
~Define Components~
Thank you for your help in advance,
Markus
sinan
Post by sinan »
I pasted this code into an empty script and it worked fine.
Are you using the latest version (update 1)?
Any more details you might be able to provide?
casic
Post by casic »
I tried it with update 1 - the same error occured. I'm developing a setup to install MSDE. The setup copies all MSDE installation files to the target dir and then runs the MSDE Setup - all works perfect (install/uninstall) except the displayed size... Do you need any files to reproduce this behaviour?
Thanx,
Markus
sinan
Post by sinan »
I cannot reproduce it when I paste the lines you provided into an empty script. It might be good if you could send me the MIA and MPR files for the project that causes this error.
sinan
Post by sinan »
We have successfully reproduced this issue and resolved it. Thank you for catching this one!
Expect an update later today.
casic
Post by casic »
Great - I will check it :D
casic
Post by casic »
I checked out the new build (downloaded 09-09-05) but the same error still occur. Version of InstallAWARE: sp1.passion_update1_rtm.050905
cu
Markus
sinan
Post by sinan »
Please install the latest build (050909), regenerate your license file (if you have one) and reinstall it, then try again.
