I want to write some simple scripts to validate Zip Code on a dialog.
I have set the max length = 5
Which functions should I use to allow user only input digit?
Thanks in advance!
Zip Code validation
Re: Zip Code validation
swarovski wrote:I want to write some simple scripts to validate Zip Code on a dialog.
Thanks in advance!
I have given up the validation.
And currently using a mask edit box.
prevent user from input letters..
_regValidateZipCode = $_regZipCode$ + 0
if Variable _regValidateZipCode Equals
Set Variable _regValidateResult to $_regValidateResult$$NEWLINE$- Zip Code <invalid>
I am glad I found this method.
main idea is using mathematics function.
a valid number will always return a number
else will return empty string
Users browsing this forum: No registered users and 55 guests
