Is it possible to use variable in a sql script with MY SQL plugin and #FILESCRIPT# ?
Here is an example of what I need to do in my .sql script:
CREATE DATABASE `$DBNAME$` DEFAULT CHARACTER SET utf8 COLLATE utf8_general_ci;
USE $DBNAME$;
With $DBNAME$ set dynamically through a dialog.
Since the whole script is very long I cannot load it statically because that makes the application hang.
Any Idea ?
Thanks !
