Setting enabled to false on a control in the dialog editor
jls
Post by jls »
Setting enabled to false on a control in the dialog editor is not very smart.
If you do so your not able to select the control to modify it. (save and load the form)
Is this a bug or do I do something wrong?
Jørgen
jimo
Post by jimo »
Just click the save button again when you open the dialog to edit edit it and the disabled controls will appear.
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
jls
That is the problem
Post by jls »
The problem is how do you select the control to enable a disabled control.
The only solution I have found is to cut and paste a control to a text editor remove the enabled property and paste it back
Jørgen
