SQL Script
Lin
SQL Script
Post by Lin »
I am wondering if there is any good way to the location of the master databse mdf and ldf files in InstallAware.
I need this location in order to install my other database files that I need to attach.
BrandonK
Post by BrandonK »
Lin,
My install runs a SQL script to create the app database from scratch. It finds the path to master.mdf using the code below.
Not sure how you could do this in IA script; SQL scripting isn't my strong suit. Maybe run the first half in an IA "MS SQL Server" action and return @SQLDataPath into an IA variable?
DECLARE @SQLDataPath AS NVARCHAR(256)
SET @SQLDataPath = (
	SELECT SUBSTRING(physical_name, 1, CHARINDEX('master.mdf', LOWER(physical_name)) - 1)
	FROM master.sys.master_files
	WHERE database_id = 1 AND file_id = 1
EXECUTE ('
	CREATE DATABASE [YOUR_DB_NAME]
	ON (
		NAME = ''YOUR_DB_NAME'',
		FILENAME = ''' + @SQLDataPath + 'YOUR_DB_NAME.mdf'',
		SIZE = 3072KB ,
		MAXSIZE = UNLIMITED,
		FILEGROWTH = 10%
	LOG ON (
		NAME = ''YOUR_DB_NAME Log'',
		FILENAME = ''' + @SQLDataPath + 'YOUR_DB_NAME.ldf'',
		SIZE = 1024KB ,
		MAXSIZE = 1GB , FILEGROWTH = 10%
	COLLATE SQL_Latin1_General_CP1_CI_AS
GO
Hope this helps,
Brandon
