Hi all,
Newbie here. I am evaluating your InstallAware product with the possible purchasing it soon. It works fine if I tried to create a package without using the SetupCapture feature.
However, that is not what I want to do. I want to repackage an installation and create an installer of it. When I tried to use the SetupCapture, it went through the process of capturing, then it said “now you can open it in InstallAware”. I opened that MPR file in InstallAware and tried to Compile it. I received this error message:
Cannot open file "c:\\documents and settings\\ttran\\ntuser.dat.LOG". The process cannot access the file because it is being used by another process
Then I tried to Build it, it gave me the same error message
Please advise what is wrong with it. How do I fix the problem? Did I not set it up correctly? I need this sorted out soon so I can give a recommendation to my boss.
Thanks for your response/support.
[/b]
Error message when using Setup Capture feature
Users browsing this forum: No registered users and 37 guests
