Check Registry and Read Registry
swarovski
Postby swarovski » Mon Jun 18, 2007 3:30 am
What is the difference between these 2?
Check Registry and Read Registry?
I want to also check whether the the registry value is available or not. (existing key or not)
Any good method?
Thanks in advance!
SteveDude
Check Registry
Postby SteveDude » Mon Jun 25, 2007 5:26 pm
CheckRegistry is for what you are asking...
Value Meaning
UNKNOWN$TYPE The value exists, but is of an unknown type.
BINARY$VALUE The value exists, but is a binary type that cannot be read with this command.
NO$VALUE The specified key exists, but the specified value does not exist.
NO$KEY The specified key does not exist.
READ$ERROR An error occured during the read operation (check access privileges).
The best thing to do is press the F1 key when you are in a command dialog for a good description
swarovski
Postby swarovski » Tue Jun 26, 2007 1:02 am
Coolies. thanks a lot!
I will use F1 next time. ;p
Users browsing this forum: No registered users and 103 guests
