Removing a Windows Service not working when uninstalling
Edhy
Post by Edhy »
I am installing a Windows Service and when running uninstall to remove the application, the service is not being removed from the Services Panel.
Can anybody tell me what am I doing wrong here:
[DEFINE REGION: Perform Uninstallation]
if Variable REMOVE Equals TRUE
  Comment: Uninstall product
  Comment: TO-DO: Insert any additional uninstall commands here
  Apply Uninstall (get result into variable SUCCESS)
      Run Program $BootDrive$\\Progytech\\ezCallTrack\\cdrServer\\R2.bat  (WAIT)
         Terminate Program
      Control Service ezCallTrack_Service: stop and delete on uninstall [wait for completion]
  Set Variable PROGRESS to 100
END REGION
~InstallAware Clipboard Data~
~Code Folding Region~
~{21EA8D3E-4D4F-48A9-A9A3-36FD1838CED9}~
~FALSE~
~Else~
~{C0B5F0A1-FC97-401C-98E0-ECD9B4EB1B3A}~
~Set Variable~
~{2E82A4FB-4008-4C0B-88CA-1BAAAFAD28D5}~
~PROGRESS~
~100~
~End~
~{96BC4C1C-B51E-468E-9E34-C9AADA6E61E0}~
~End~
~{A9E53720-DADB-49D7-9F1F-A1C1483DFC93}~
~Control Service~
~{5FFBC9CE-A277-4033-BEDE-80D68AD058D7}~
~ezCallTrack_Service~
~5~
~2~
~TRUE~
~Terminate Program~
~{F33BC218-A452-4D0B-8F1E-55E61E79C71B}~
~CDRServerLib.WinServiceProcessing~
~Run Program~
~{5EB2D5A5-C49B-4093-82E9-EAAB5E7DE6D7}~
~$BootDrive$\\Progytech\\ezCallTrack\\cdrServer\\R2.bat~
~TRUE~
~TRUE~
~Run Program~
~{3E7C0B38-F0D1-4049-AA1C-2AE896295D51}~
~$BootDrive$\\Progytech\\ezCallTrack\\cdrServer\\RegAsm.exe~
~TRUE~
~$BootDrive$\\Progytech\\ezCallTrack\\cdrServer\\CDRcryptolib.dll" /silent /unregister~
~TRUE~
~If~
~{B83A0853-7592-49DE-A579-CFF59889F876}~
~SUCCESS~
~0~
~CANCEL~
~TRUE~
~If~
~{EA2F5773-EB22-48FC-BA35-9BED5409EAF1}~
~SUCCESS~
~0~
~ERROR~
~TRUE~
~Apply Changes~
~{D59A2781-84C4-49C3-A728-1C037223C379}~
~progress~
~SUCCESS~
~FALSE~
~TRUE~
~Comment~
~{F69F7142-0D77-4690-98FD-9EF1F40DA024}~
~TO-DO: Insert any additional uninstall commands here~
~Comment~
~{4A34ECC4-DCB2-4A96-8626-0392ECB62314}~
~Uninstall product~
~If~
~{B4825525-0856-4BC3-B82A-B5DF2BC32720}~
~REMOVE~
~0~
~TRUE~
~FALSE~
~{7C057E02-39B7-4FB5-8758-3F6743FE5D49}~
~TRUE~
~Perform Uninstallation~
When the above code run, I expect the service to be removed from the Services Panel, but it is not happening.
Thanks!
Edhy Rijo
Edhy
Post by Edhy »
I found the problem!!!
The code to handle the service was after the Apply Install, which obviously when getting familiar with IA I figured out it will not work. So just to be on the safe side, I created a new simple script to test the Service control and then noticed that even you selecting an action to be done at the Uninstall level, it does keep the code just before the Apply Install so I re-arranged the original script and it is working fine now.
P.S.
Is there a way, maybe in future version for IA to let the user know that some commands will not work after Apply Install is being issued, maybe at compiling level, to trigger a warning.
Edhy Rijo
