How do I:
- Prevent the installation to be included in Add/Remove programs ?
- Get rid of the Run program option at
the end of the installtion ?
- Run other MSI/Exe programs during installation ?
Using IA 6.6 Studio
David
Options
Hi David,
I'll try to answer your questions.
1- Prevent the installation to be included in Add/Remove programs ?
I really don't know, but maybe if you don't fill the info for the Add-Remove it iwll not be shown there.
2- Get rid of the Run program option at the end of the installtion ?
I solve this by creating a copy of the Finish dialog and in my copy delete the object named RunNow, then in the script use your new dialog instead of the Finish one.
3- Run other MSI/Exe programs during installation ?
Use the Run Program command from the "Direct Execute" options and fill in the parameters to run your program.
Good luck!
Good luck!
Edhy Rijo
Users browsing this forum: No registered users and 88 guests
