Rename setup
manso
Rename setup
Post by manso »
We have an installer which has been called Product10.exe (output filename). We renamed it to ProductSetup.exe. Our installation supports multiple instances of the same installation. When we run the installer after the product has been renamed it complains after the apply installation part that it can't find "Product10.msi" and prompts for us to enter the installation directory where it can find Product10.msi. This only happens if other installations exists on the target machine.
We figured that had to do with the product code and generated a new one but it still prompts for Product10.msi. I did a "find in file" in the InstallAware files directory for "product10" and it doesn't exist.
Anyone knows what we might have done wrong?
- Manso
