Web Block Download Failures...
mecg
Postby mecg » Tue Jun 26, 2007 3:00 pm
Just an FYI...
I have set up a web deploy installation that continually failed when it came time to download the web blocks. I renamed the blocks from the default ".7zip" extension to the picked-out-of-thin-air extension of "ias" (short for InstallAware Setup). :) After doing that the blocks download perfectly...
Thanks...
Postby CandiceJones » Tue Jun 26, 2007 8:44 pm
7zip was probably a disallowed file type or unregistered mime extension on your server.
Return to “Non-Technical”
Users browsing this forum: No registered users and 127 guests
